Solved! Go to Solution.
Jamal, based on several other threads, I'm at a loss as to why you are using the Web Applications Manager. Given all of the details you have provided, it is not necessary to have this installed.
http://resources.arcgis.com/en/help/main/10.1/index.html#//0154000002p0000000
try see http://support.esri.com/en/knowledgebase/techarticles/detail/35058
The Web Application Developer Framework (ADF) that shipped with previous versions of ArcGIS Server is deprecated, and developers should use the ArcGIS web APIs (for JavaScript, Flex, and Silverlight) when writing new web applications. Printing, editing, and other tasks previously accomplished through the ADF are now readily available using the ArcGIS web APIs.
The ADF continues to ship with ArcGIS 10.1 for Server as a separate setup named ArcGIS Web Applications. This exists solely for the purpose of supporting legacy applications. The setup includes ArcGIS Web Applications Manager, a legacy version of Manager that allows you to view and modify your web applications.
