Error: ???Revoke database owner from the SDE login???
5812
5
12-17-2012 11:04 AM
by Anonymous User
Not applicable
Original User: Jamal432@gmail.com
Error: �??Revoke database owner from the SDE login�?�
I tried to �??create an enterprise geodatabase�?� but I got the error shown in the screenshots below:
[ATTACH=CONFIG]20014[/ATTACH], [ATTACH=CONFIG]20015[/ATTACH]
[To create an SDE schema geodatabase, revoke database owner from the SDE login.]
See the setup log in the following location for additional error information:
C:\Users\m\AppData\Local\Temp\sde_setup.log
Could not create  geodatabase tables and stored procedures.
Failed to execute (CreateEnterpriseGeodatabase).
What might be the problem?
Thank you for the answer
Best
Jamal
by Anonymous User
Not applicable
Original User: JSkinn3
Hi Jamal,
It appears you may have the 'sysadmin' role applied to your SDE user.  You can revoke this in SQL Server Management Studio by going to the Security folder > Logins> right-click on the SDE user > Properties > Server Roles.  Uncheck 'sysadmin'.
KarenLizcano1
thanks!!!
JamalNUMAN
Legendary Contributor
Hi Jamal,
Thank you Jake for the answer. It works.
[ATTACH=CONFIG]20018[/ATTACH], [ATTACH=CONFIG]20019[/ATTACH]
Best
Jamal
Jamal Numan
by Anonymous User
Not applicable
Original User: dougcurl
I just had this issue and that solution didn't work for me - I got a "not enough permissions" type error. But I followed the solution here: http://support.esri.com/en/knowledgebase/techarticles/detail/40606
And simply re-connected to the geodatabase I wanted to enable with my "sa" user instead of "sde" and ran the "Enable Enterprise Geodatabase" Tool, and that worked.  So you might try that alternative if someone comes across this thread.
JamalNUMAN
Thanks douglas. This is useful.
Best
Jamal
Jamal Numan
