Every superiors: Now I have a question like this, [ATTACH=CONFIG]34461[/ATTACH],this can control the map span �?when click the west button[ATTACH=CONFIG]34462[/ATTACH]�?the map can move to left�?when click the east [ATTACH=CONFIG]34463[/ATTACH]�?the map can move to right�?and other like this�?if there is a component in the esri�?or you can the solve method�?wait for your answer�?thanks very very much�??
The ESRI web map control has navigation UI controls but they are a bit different to the Google panning control - see this example: http://jsbin.com/voxosido
You can enable these pan controls using the 'nav: true' option when creating your map, for example:
