Split Coplanar Faces not working
1489
06-08-2014 07:28 AM
by Anonymous User
Not applicable
Original User: paulhoepner
I am trying to split overlapping, coplanar faces, and merge them into one, but the "clean up shape" option does not seem to work. What am i doing wrong? heres a screen of my settings and the object I want to clean up:[ATTACH=CONFIG]34432[/ATTACH][ATTACH=CONFIG]34432[/ATTACH]
[ATTACH=CONFIG]34433[/ATTACH]
I convetrted the object to shapes, and also tried separating the faces to single shapes and then using the clean up option, but it never works.
Any Ideas?
by Anonymous User
Not applicable
Original User: matthiasbuehler
hi ..
can you create a clearer screenshot of only the shapes that you try to merge ?
let me know ..
m.
MatthiasBuehler1
hi ..
hmm. I'm not sure what precisely this is..
can you post the cej file with just these 3 shapes and the texture in a zip file ?
lemme know..
by Anonymous User
Not applicable
Sure:
I made Shapes, then tried to apply the clean up. i selected the faces single, for you to see the edges:
Shape:
http://www.directupload.net/file/d/3651/6f6sz3no_png.htm
face 1
http://www.directupload.net/file/d/3651/urlul62k_png.htm
http://www.directupload.net/file/d/3651/zwzejjgm_png.htm
face 2
http://www.directupload.net/file/d/3651/ofkwzr8e_png.htm
http://www.directupload.net/file/d/3651/z774kw5w_png.htm
both faces:
http://www.directupload.net/file/d/3651/s6kvf4pe_png.htm
clean up settings:
http://www.directupload.net/file/d/3651/igbqljpu_png.htm
Hope that helps. When running the clean up, nothing in the mesh changes. I tried changing the thresholds, but that only displaces the meshes ...
Thanks for trying to help!
