Reversing Polygon color fills uupon export
1676
06-05-2014 09:53 AM
BrandonMcLaughlin
This happens on any 10.x Arcmap version.
After importing a polygon from a google earth kml, there's an issue when exporting the map to pdf/bmp/png/etc...   with a reversing color fill. It will entirely fill the wrong area. Please refer to the images attached.
I've noticed at 96dpi exports, the fill will remain in its correct form - but any higher, then this issue always crops up and the fill is entirely flipped.
Correct:
[ATTACH=CONFIG]34394[/ATTACH]
After Export:
[ATTACH=CONFIG]34395[/ATTACH]
by Anonymous User
Not applicable
Original User: jimcousins
It is possibly a problem with the polygon geometry. Try running Data Management Tools >> Features >> Repair Geometry, and see if that resolves the problem.
If not, you could try exporting to a new shapefile, or put it into a Geodatabase, and see if that helps.
Best Regards,
Jim
BrandonMcLaughlin
Thankyou for your response.
I want to report it really was easy to fix this using repair geometry tool.
BrandonMcLaughlin
One more comment:
if repair geometry doesn't work - export to shapefile, and if that doesn't work - repair the new shapefile.
This worked when a straightforward repair didn't. thankyou jimcousins
