Pixelated shape file
4152
6
06-02-2014 04:24 AM
by Anonymous User
Not applicable
Original User: prashant_tiwari
Hello Friends,
New user in arc gis need some help.
When i import any shape file (drag and drop) in arc map It looks pixelted.
So can you help me to resolve this problem i need smooth lines,
I attached the image files along with this post.
First one is what arcmap is showing to me and the 2nd is what i want.
Thanks in advance.
[ATTACH=CONFIG]34251[/ATTACH][ATTACH=CONFIG]34252[/ATTACH]
MelitaKennedy
Esri Notable Contributor
What happens if you run the Check Geometry tool (and Fix Geometry on a copy of the data) on the data? If a polygon won't properly "fill" with color, it usually means that the polygon is not properly closed.
Melita
by Anonymous User
Not applicable
Melita
Thanks for reply me but my question was not that if u see the attached file [ATTACH=CONFIG]34285[/ATTACH]
You will come to know whats my question is.
And i also check the Gemetry tool but all polygon are closed.
I just want line shows without Pixelated.
JenniferDvorsky
Were you able to fix this issue? I am having the same with all my shapefiles/feature classes. Were you using MapLogic when this happened?
by Anonymous User
Not applicable
Original User: Cartographer
I think that's a consequence of screen drawing without anti-aliasing.
How does it look when you print it or export it?
JenniferDvorsky
The exports are pixelated as well unless I crank up the resolution. I've never had any problems around 300dpi but now it requires at least 500 to appear smooth.
by Anonymous User
Not applicable
I admit I don't know a lot about export.
Is there any transparency or picture-based symbology or anything like that in your map? What file format are you exporting to? Have you tried other formats?
