Adding �??File Geodatabase�?� to the ArcGIS Online,
684
05-31-2014 10:26 AM
JamalNUMAN
Legendary Contributor
I couldn�??t figure out how the �??file geodatabase�?� can be added to the ArcGIS Online.
[ATTACH=CONFIG]34221[/ATTACH]
As an attempt, I compressed the �??file geodatabase�?� in *.ZIP file and added it to the ArcGIS Online. This appears not to work.
[ATTACH=CONFIG]34220[/ATTACH], [ATTACH=CONFIG]34222[/ATTACH]
Then how the �??file geodatabase�?� can be added to the ArcGIS Online?
Thank you
Best
Jamal
Jamal Numan
by Anonymous User
Not applicable
Original User: timw1984
In one of the posts I read about the same question ESRI stated, that while you can upload a file geodatabase, there is no support yet with which you are able to use the file geodatabase in an actual map yet.
JamalNUMAN
Thanks Tim,
Best
Jamal
Jamal Numan
