AnsweredAssumed Answered
Procedure Entry Point Error when executing City Engine Trial
Question asked by geonetadmin on Feb 26, 2014
Original User: sandhyageo@gmail.com
Original Date: 2014-02-26T21:08:20-0600
Hello All
I have installed City Engine on my system using 30 day trial version. I need to test the software for building roof texturing using Ortho rectified imagery. I think it is possible in ESRI City Engine. When I execute the program, it shows error that
'The procedure entry point SymRefreshModuleList could not be located in the dynamic link library dbghelp.dll'
If I give ok then another error came that
'This application has failed to start because com.esri.prt.core.dll was not found. Re-installing the application may fix this problem'
Then I re-install the program and again tried but the problem exists. But the software opens with the error. I cannot import or use the software. I have attached screen shots of the error.
My system configuration are
OS: Windows XP 64 bit, Service pack 2
Processor: Intel(R) Core(TM) i7-2600k
RAM: 16 GB
CPU: 3.40 GHz
Display: NVIDIA Quadro FX 550
Kindly help me to fix this issue.
Thank you
Outcomes
