How to sort the values of a domain out alphabetically?
746
02-26-2014 03:45 AM
JamalNUMAN
Legendary Contributor
I have added the values of the ???Ref_C_MOLG??? field (from ???Communities_Points??? layer) as domain to the ???G??? geodatabase. These values are linked to a field of other table.
The issue here that these values are not ordered alphabetically.
[ATTACH=CONFIG]31758[/ATTACH], [ATTACH=CONFIG]31759[/ATTACH], [ATTACH=CONFIG]31760[/ATTACH]
Is there a way to sort out the values of the domain alphabetically?
Thank you
Best
Jamal
Jamal Numan
by Anonymous User
Not applicable
Original User: mboeringa2010
Jamal, you should use the Help a bit more often ;):
Sort Coded Value Domain (Data Management)
by Anonymous User
Not applicable
JamalNUMAN
Many thanks Marco. It works fine.
[ATTACH=CONFIG]31764[/ATTACH]
Best
Jamal
Jamal Numan
