3D GeoCoding -- AGSLocator with Z-Axis
3239
02-02-2014 11:48 PM
MariusGächter
hi fellows,
I've got a GeoCoding-Service from my customer. They configured it to return a Point with X,Y and Z Axis for a given Address.
However, using AGSLocator I receive only X- and Y-values. (btw. I use the IOS SDK 10.2)
Is there a possibility to solve this Problem?
Request using the webinterface:
[ATTACH=CONFIG]31061[/ATTACH]
Request using AGSLocator:
[ATTACH=CONFIG]31062[/ATTACH]
Thanks a lot.
marius
DiveshGoyal
We currently don't support z values in geometry.
I would be interested in knowing how you plan to use the z values considering that the map only supports 2D display.
DiveshGoyal
by Anonymous User
Not applicable
Original User: leafit
thanks, technobrat.
We plan to create something like an "inhouse navigation system" we have esri-webservices containing the rooms grouped by floors. We would like to use the geocoding and the routing-services to display the shortest path from one room to another to the user. The Z-Axis is somewhat fictive (its meter above sealevel + floornumber x 3m), we use it to determine on which floor the room is.
Are my explanations more or less clear?
What would you say, is this a possible scenario?
