I'm experiencing a lot of problems trying to properly register my AWS geodatabase. I'm trying to troubleshoot whether the AWS image isn't configured properly and what I need to change to properly register my GDB for use. As a sub-problem, I have found a weird bug that might be contributing to my problem.
When I register a GDB with ArcCatalog, the results in the web-based Manager are different. No matter what I configure for the Server Database Connection, the web-based Manager shows the exact same thing. See screenshots for a visual example (note I've just deleted some IP and password hash data so ignore the blanks)
Again, no matter what I put in, I always get the same result. If I use a different GDB, instance, username, etc. It's always owner, EGDBHOST, geodata. etc.
Is this a cosmetic issue or is there something weird happening with the database registration?
