Graduated symbology of raster. How to round maximum value (automated)
2025
12-21-2013 07:17 AM
by Anonymous User
Not applicable
Original User: colinmurray
Hello
I'd like to know if there's a way to automate rounding the maximum value for a raster when rendered in Stretched values along the colour ramp.
The value default is to 3 decimal places but I'd like it rounded to a whole number for aesthetic reasons.
I know how to do this manually. However the number of rasters I have to do this to is rather large and so I'd like to automate the process. Please see below images of before and after for what I want.
[ATTACH=CONFIG]30061[/ATTACH]
[ATTACH=CONFIG]30062[/ATTACH]
Thank you
Colin
JeffBarrette
Stretched is currently not supported via arcpy.mapping.
Jeff
JeffBarrette
Have you tried using arcpy.mapping.  Here is an example from the help that demonstrates how to set the values and labels.
import arcpy
mxd = arcpy.mapping.MapDocument(r"C:\Project\Project.mxd")
df = arcpy.mapping.ListDataFrames(mxd, "Census")[0]
lyr = arcpy.mapping.ListLayers(mxd, "StatePopulation", df)[0]
lyrFile = arcpy.mapping.Layer(r"C:\Project\LYRs\Population.lyr")
arcpy.mapping.UpdateLayer(df, lyr, lyrFile, True)
if lyr.symbologyType == "GRADUATED_SYMBOLS":
  lyr.symbology.valueField = "POP2000"
  lyr.symbology.classBreakValues = [250000, 999999, 4999999, 9999999, 35000000]
  lyr.symbology.classBreakLabels = ["250,000 to 999,999", "1,000,000 to 4,999,999",
                                    "5,000,000 to 9,999,999", "10,000,000 to 35,000,000"]
arcpy.mapping.ExportToPDF(mxd, r"C:\Project\Output\StatePopulation.pdf")
del mxd, lyrFile
Jeff
by Anonymous User
Not applicable
Arc.py.mapping is what I'm using. And I must say it's pretty sweet once I broke the code.
What you've suggested seems to work when creating class breaks but I don't see a similar function to apply to stretched values as I have decided to use. You can see from the screen clip (showing the layer properties box) that I can manually change the Label to round off to 4915 from 4915.29. How to do this via automation?
Thank you for the response.
[ATTACH=CONFIG]30133[/ATTACH]
JeffBarrette
Jeff
by Anonymous User
Not applicable
Thank you for letting me know.
Cheers
Colin
