Hi....
I always fail to register my sqlserver to ArcGIS Server.
The following message was:
"The connection property set was missing a required property or the property value was unrecognized. Failed to access the DBMS server"
I can access the SQLServer from the database connection but can not register it.
Do you have suggestion for me?
Thank you
Which user are you using to register the database?
I use the admin, but still can not register the database
which admin? a Windows login or a database authenticated login?
Oh, the database login. Is there one of the reason I failed?
No, not really.
Try registering from ArcCatalog if you haven't already. Create a ADMIN server connection and then use that to try and register.
Yeah, I have already done it, but I still have the same problem.
Hmm.. I did install the Native Client for SQLServer in server which I installed the ArcGIS Server.
In my case, the ArcGIS Server and SQL server are in different server.
Thank You
Did you install the 64-bit version of Native Client (assuming that your ArcGIS Server is a 64-bit machine)
Also, try to register using the IP Address instead of the Hostname an check if that helps.
I also have the same issue. Did you solve it finally?
Same issue as well using AGP 3.1.2 and ArcGIS Server 10.9.1. Anyone have any updates by chance?
