A tool that can �??create replica�?� for both layers and tables,
It is very frustrating that the �??create replica�?� tool is only able to create replica for spatial data (feature classes) but the tables are left with no replication.
[ATTACH=CONFIG]29500[/ATTACH],
The other tool that is used to create replica for tables (non-spatial data) is �??create replica�?� command available in the �??distributed geodatabase�?� tool bar.
[ATTACH=CONFIG]29501[/ATTACH], [ATTACH=CONFIG]29502[/ATTACH]
I�??m wondering why there is no one single tool that can create replica for both tables (non-spatial data) and layers (spatial data) in one go.
I have previously raised this issue but couldn�??t find a sophisticated solution.
Thank you
Best
Jamal
Thank you
Best
Jamal
The "Create Replica" option in the Distributed Geodatabase toolbar is not specifically for tables and is used to replicate Spatial data as well. I'm not quite sure why you are unable to use that.
An overview of the Distributed Geodatabase toolset:
http://resources.arcgis.com/en/help/main/10.1/index.html#//001700000013000000
The above link mentions that the "Create Replica" tool..
Also, here is another Forum discussion which you can have a look at:
http://forums.arcgis.com/threads/48195-Create-Replica-on-SDE-Table?p=166604#post166604
