Original User: Hedwig
Updating the Maplevels of representations by code isn't possible.
I can by code change the Maplevel however the Symbol Levels Dialog doesn't show the changed Maplevels. In the Actieve View the inserted Maplevels aren't used neither. However exporting the, changed, Maplevels shows the by code changed Maplevels.
I'm able to change all other Symbology types and change the other options of the Representations.
Here's is the code for importing the Maplevels from a dictionary. The value of the dictionary is a list of symbol levels.
[ATTACH=CONFIG]28752[/ATTACH]
if (pGroupedLayer is IFeatureLayer & pGroupedLayer is ISymbolLevels & pGroupedLayer is IGeoFeatureLayer)
layerName = pGroupedLayer.Name;
IGeoFeatureLayer pGeoFLayer = (IGeoFeatureLayer)pGroupedLayer;
ISymbolLevels pSymbLevels = (ISymbolLevels)pGeoFLayer;
pSymbLevels.UseSymbolLevels = true;
IFeatureRenderer pFeatRen = pGeoFLayer.Renderer;
if (pFeatRen is IRepresentationRenderer)
IRepresentationRenderer pRepRen = (IRepresentationRenderer)pFeatRen;
IRepresentationClass repClass = pRepRen.RepresentationClass;
IRepresentationRules pRepRules = repClass.RepresentationRules;
pRepRules.Reset();
int OutIdx = 0;
IRepresentationRule pRepRule;
pRepRules.Next(out OutIdx, out pRepRule);
IMapLevel pMapLevel;
while (!(pRepRule == null))
repName = pRepRules.get_Name(OutIdx).ToString();
if (_visualizationEntries.ContainsKey(layerName + repName))
visEntry = _visualizationEntries[layerName + repName];
List<int> lstSymbolLevels = visEntry.SymbolLevels;
for (int k = 0; k < pRepRule.LayerCount; k++)
IBasicSymbol pRepLayer = pRepRule.get_Layer(k);
if (pRepLayer is IBasicMarkerSymbol)
IBasicMarkerSymbol pBasMarkSym = (IBasicMarkerSymbol)pRepLayer;
pMapLevel = (IMapLevel)pBasMarkSym;
oldMapLevel = pMapLevel.MapLevel;
newMapLevel = lstSymbolLevels;
pMapLevel.MapLevel = newMapLevel;
newMapLevel = pMapLevel.MapLevel;
else if (pRepLayer is IBasicFillSymbol)
IBasicFillSymbol pBasFillSym = (IBasicFillSymbol)pRepLayer;
pMapLevel = (IMapLevel)pBasFillSym;
else if (pRepLayer is IBasicLineSymbol)
IBasicLineSymbol pBasLineSym = (IBasicLineSymbol)pRepLayer;
pMapLevel = (IMapLevel)pBasLineSym;
else
I also tried
if (pLayer is IGeoFeatureLayer)
pGeoFLayer = pLayer as IGeoFeatureLayer;
if (pGeoFLayer.Renderer is IRepresentationRenderer)
ISymbolLevels symLevels = (ISymbolLevels)pGeoFLayer;
symLevels.UseSymbolLevels = true;
IRepresentationRenderer oldRepRen = (IRepresentationRenderer)pGeoFLayer.Renderer;
IRepresentationClass oldRepClass = oldRepRen.RepresentationClass;
IRepresentationRules oldRepRules = oldRepClass.RepresentationRules;
Dictionary<IRepresentationRule, string> lstNewRules = new Dictionary<IRepresentationRule, string>();
oldRepRules.Reset();
int OutIdx = 0;
IRepresentationRule oldRepRule, newRepRule;
oldRepRules.Next(out OutIdx, out oldRepRule);
while (!(oldRepRule == null))
newRepRule = new RepresentationRuleClass();
string oldRepName = oldRepRules.get_Name(OutIdx).ToString();
for (int L = 0; L < oldRepRule.LayerCount; L++)
IBasicSymbol oldSymbol = oldRepRule.get_Layer(L);
if (oldSymbol is IMapLevel)
if (oldSymbol is IBasicLineSymbol)
IBasicLineSymbol oldBasicLine = (IBasicLineSymbol)oldSymbol;
IMapLevel oldMapLevel = (IMapLevel)oldSymbol;
else if (oldSymbol is IBasicMarkerSymbol)
IBasicSymbol newSymbol = new BasicMarkerSymbolClass();
IGraphicAttributes2 newGraphAttr = (IGraphicAttributes2)newSymbol;
IMapLevel newMapLevel = (IMapLevel)newSymbol;
IGraphicAttributes2 oldGraphAtrr = (IGraphicAttributes2)oldSymbol;
for (int O = 0; O < oldGraphAtrr.GraphicAttributeCount; O++)
int ID = oldGraphAtrr.ID;
object Val = oldGraphAtrr.get_Value(ID);
string Name = oldGraphAtrr.get_Name(ID);
newGraphAttr.set_Value(ID, Val);
newMapLevel.MapLevel = oldMapLevel.MapLevel + 3;
newRepRule.InsertLayer(L, newSymbol);
else if (oldSymbol is IBasicFillSymbol)
lstNewRules.Add(newRepRule, oldRepName);
oldRepRules.RemoveAll();
foreach (KeyValuePair<IRepresentationRule, string> kvp in lstNewRules)
int RuleId = oldRepRules.Add(kvp.Key);
oldRepRules.set_Name(RuleId, "Nieuw" + kvp.Value);
oldRepClass.RepresentationRules = oldRepRules;
oldRepRen.RepresentationClass = oldRepClass;
pGeoFLayer.Renderer = (IFeatureRenderer)oldRepRen;
else
pGeoFLayer = null;
Both times I update the folowing objects;
if (pGeoFLayer != null)
//This makes the layer properties symbology tab show the correct interface.
IUID pUID = new UIDClass();
pUID.Value = "{683C994E-A17B-11D1-8816-080009EC732A}";
pGeoFLayer.RendererPropertyPageClassID = pUID as UIDClass;
IMxDocument MxDoc = (IMxDocument)mapDoc;
MxDoc.UpdateContents();
mapDoc.ActiveView.ContentsChanged();
mapDoc.ActiveView.Refresh();
IContentsView contVieuw = MxDoc.get_ContentsView(0);
contVieuw.Refresh(null);
