Disable a command button within an Add-In
3414
7
10-17-2013 08:14 AM
by Anonymous User
Not applicable
Original User: Genaro Garcia
I need to disable a command button within an Add-In when ArcMap is started.
I added "OnDemand = false" option in the Config.esriaddinx, but still not working.
It actually crashes ArcMap. See attached document to view the code and error message.
I may be doing something wrong, but not sure.
Any help is greatly appreciated.
GenaroGarcia
New Contributor III
I solved the crashing issue.
1. I removed "OnDemand = false" from the Config.esriaddinx.
2. I deleted the current add-in.
3. I deleted the Normal.mnt.
Now my question is, How do you disable a command button add-in when ArcMap is started?
by Anonymous User
Not applicable
Original User: kenbuja
Here's an example of a tool where a command button is enabled if there are two registry keys.
This is the Config.esriaddinx
  <AddIn language="CLR" library="MPA_SPARC.dll" namespace="MPA_SPARC">
    <ArcMap>
      <Commands>
        <Button id="Biogeography_Branch_MPA_SPARC_btnAnalyze" class="btnAnalyze" message="Start the main Analysis tool" caption="Analyze" tip="Analyze" category="Biogeography Branch Add-In Controls" image="Images\btnAnalyze.png" onDemand="false" />
and this is the code for the command
Public Class btnAnalyze
    Inherits ESRI.ArcGIS.Desktop.AddIns.Button
    Public Sub New()
    End Sub
    Protected Overrides Sub OnClick()
        //the click task
    End Sub
    Protected Overrides Sub OnUpdate()
        Dim KeyExist As Boolean
        KeyExist = (My.Computer.Registry.GetValue("HKEY_CURRENT_USER\SOFTWARE\Biogeography Branch\SPARC", "MPA", Nothing) IsNot Nothing)  And
            (My.Computer.Registry.GetValue("HKEY_CURRENT_USER\SOFTWARE\Biogeography Branch\SPARC", "Resources", Nothing) IsNot Nothing)
        Enabled = (My.ArcMap.Application IsNot Nothing) And KeyExist
    End Sub
End Class
GenaroGarcia
New Contributor III
I inserted, onDemand ="false" statement in the button of the config again, which caused ArcMap to crash.
I getting the same results as the previous time.
<ESRI.Configuration xmlns="http://schemas.esri.com/Desktop/AddIns" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
  <Name>OKC_FixArcs_Cmd</Name>
  <AddInID>{2b2b3fd4-6c5e-45b6-b378-232e81da046f}</AddInID>
  <Description>"Smooths the arc by inserting vertices using the density method only on polyline and polygon feature classes"</Description>
  <Version>1.0</Version>
  <Image>Images\OKC_FixArcs_Cmd.png</Image>
  <Author>Genaro L. Garcia, Jr.</Author>
  <Company>City of Oklahoma City</Company>
  <Date>10/15/2013</Date>
  <Targets>
    <Target name="Desktop" version="10.0" />
  </Targets>
  <AddIn language="CLR" library="OKC_FixArcs_Cmd.dll" namespace="OKC_FixArcs_Cmd">
    <ArcMap>
      <Commands>
          <Button
            id="City_of_Oklahoma_OKC_FixArcs_Cmd_OKC_FixArcs" class="OKC_FixArcs" tip="Fix Arcs" message="Smooths the arc by inserting vertices using the density method only on polyline and polygon feature classes" caption="Fix Arcs Cmd" category="Add-In Controls" image="Images\OKC_FixArcs_Cmd.png" onDemand="false />
      </Commands>
    </ArcMap>
  </AddIn>
</ESRI.Configuration>
by Anonymous User
Not applicable
Do you have the quotes closed correctly? Your line finishes with this
 onDemand="false />
which is missing the final quote
 onDemand="false" />
GenaroGarcia
New Contributor III
Yes, Ken, I fix that problem, onDemand = "false".
Still crashes ArcMap.
At this point, I wrote code to check to see the edit status in order to us the command tool.
by Anonymous User
Not applicable
Here's how I have one button in an addin that only is enabled when the editor has started.
        Me.Enabled = My.ArcMap.Editor.EditState <> ESRI.ArcGIS.Editor.esriEditState.esriStateNotEditing
    End Sub
The next thing to do is to put Try..Catch blocks in your code to see where and why it is crashing
JeraldAllen
New Contributor III
Late in the game I know, I did however just hit this issue and resolved it by using onDemand="0" instead of onDemand="false"
