AnsweredAssumed Answered
Export Map from Layout View gives white spots in PDF and print
Question asked by jwingate on Oct 10, 2013
Latest reply on Oct 11, 2013 by geonetadmin
Hello ArcGIS friends,
When creating a PDF via File-->Export Map from the Layout View, I get white spots in several places on the document, both in the PDF and when printing directly via File-->Print. When exporting to PDF or printing directly from the Data View, these spots are not visible. Please see the 3 attached PDF files for reference. ArcView 10.1.
At first I thought the spots were white ellipse shapes that I had accidentally drawn, because I did draw other white ellipse shapes to place over the gaps between a few letters of road label names, but when I try to select these elements, nothing appears to be there. I drew the shapes in the Data View mode anyway, so one would think they would appear in the Layout.
I've tried to get rid of them by manually deleting and recreating the affected labels and all elements in these areas, but the spots seem to appear in other places.
Searching threads in the forum, I found a similar issue back from 2011, but it seemed to never have been resolved:
http://forums.arcgis.com/threads/38302-when-printing-a-layout-into-pdf-file-a-white-polygons-appeared-in-the-pdf-file
I also found another thread that said the problem could be with image compression and to try LZW compression. I tried all of the available options, including lowering the output image quality, but none of those options worked.
Any thoughts? Thanks for helping out a novice user!
James Wingate
Outcomes
