AnsweredAssumed Answered
After search Dojo data Grid won't show the result and weird behavior
Question asked by geonetadmin on Jun 27, 2013
Latest reply on Jun 27, 2013 by geonetadmin
Original User: dexconor
So, this is my search
[ATTACH=CONFIG]25556[/ATTACH]
I type 5 into search box and the results are highlighted but no result shows
[ATTACH=CONFIG]25557[/ATTACH]
Below is the weird thing, if I change size of browser then it shows top of rows other wise
remains above
[ATTACH=CONFIG]25558[/ATTACH]
        findTask = new esri.tasks.FindTask("http://localhost:6080/arcgis/rest/services/fc/agr/MapServer");
        dojo.connect(map, "onLoad", function() {
          //Create the find parameters
          findParams = new esri.tasks.FindParameters();
          findParams.returnGeometry = true;
          findParams.layerIds = [2];
          findParams.searchFields = ["OBJECTID","Number","Abbrev","CampusCode"];
          findParams.outSpatialReference = map.spatialReference;
          console.log("find sr: ", findParams.outSpatialReference);
function doFind() {
     findParams.searchText = dojo.byId("searchField").value;
        findTask.execute(findParams,showResults);
      function showResults(results) {
        map.graphics.clear();
        var symbol = new esri.symbol.SimpleFillSymbol(esri.symbol.SimpleFillSymbol.STYLE_SOLID, new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_SOLID, new dojo.Color([98,194,204]), 2), new dojo.Color([98,194,204,0.5]));
        var items = dojo.map(results,function(result){
          var graphic = result.feature;
          graphic.setSymbol(symbol);
          map.graphics.add(graphic);
          return result.feature.attributes;
        var data = {
          identifier: "OBJECTID",
          label: "OBJECTID",
          items: items
        store = new dojo.data.ItemFileReadStore({ data:data });
  var grid = registry.byId('grid');
  grid.setStore(store);
        map.centerAndZoom(center, zoom);
      function onRowClickHandler(evt){
        var clickedTaxLotId = grid.getItem(evt.rowIndex).OBJECTID;
        var selectedTaxLot;
        dojo.forEach(map.graphics.graphics,function(graphic){
          if((graphic.attributes) && graphic.attributes.OBJECTID === clickedTaxLotId){
            selectedTaxLot = graphic;
            return;
        var taxLotExtent = selectedTaxLot.geometry.getExtent();
        map.setExtent(taxLotExtent);
<div class ="toggle" id="menu_subA">Enter building number, name and abbreviation<br>
  <input type="text" id="searchField" size="30" value="" /><button data-dojo-type="dijit.form.Button"  onClick="doFind();" value="Search">
        Search
      </button>
<table data-dojo-type="dojox.grid.DataGrid" data-dojo-id="grid" id="grid" data-dojo-props="rowsPerPage:'5', rowSelector:'10px'">
      <thead>
        <tr>
          <th field="Number" width="50">Num</th>
          <th field="Abbrev" width="50">Abbr</th>
          <th field="CampusCode" width="50">Camp</th>
        </tr>
      </thead>
    </table>
  </div>
I presume it's because of div that surrounded data grid?
and the div is a slide menu using jquery.
is there any way that I can fix both?
Outcomes
