AnsweredAssumed Answered
cell statistics and cost distance bounding box problem
Question asked by dabid.cabatingan on Jun 27, 2013
Latest reply on Oct 8, 2014 by xander_bakker
hello.
I am trying to make an accessibility map of the facilities in our place. I used slope, roads, and land cover (all in raster format), and facilities (in shp format).
I tried to do cell statistics between my roads and land cover data, since the merge raster is not working on ArcGIS 10. the result values were okay but the extent is not, I think it only considers the minimum bounding box of the road, i dont know. pls have a look at my attached images.
I tried to continue and compute for the cost raster using raster calculator. I believe I got the result I wanted.
Then when I tried to use the cost distance tool, input was the facilities.shp and using the cost raster, I got again a minimum bounding box of the result. please see the attached image.
My question is how can I output a same extent as my slope or landcover data. Did I miss any tool or step? Please help. I really need this problem solved. I am okay with the resulting values, it is the resulting map I having a problem with..
thank you.
Outcomes
