Where are Spatial Analyst Menu and Options ?
2585
6
06-13-2013 06:44 PM
AntoineSaurat
Hello everyone,
I am working on ArcGIS 10. Licence ok, Spatial Analyst extension ok.
At first, my toolbar was disabled (grey) but, by following these advices, I could enable it.
http://blogs.esri.com/esri/supportcenter/2011/03/18/why-are-my-spatial-analyst-and-3d-analyst-toolba...
So now I have my toolbar activated, but no menu or options is accessible.
What I want to access it this:
[ATTACH=CONFIG]25260[/ATTACH]  [ATTACH=CONFIG]25261[/ATTACH]
I hope to have any advice because I am stuck...
Thank you very much,
ShaunWalbridge
I see, that makes good sense. The training materials you're using are for ArcGIS 9.3, and the toolbar has been integrated into the rest of the geoprocessing environment in a more consistent way at ArcGIS 10. For those particular options, you'll want Geoprocessing > Environments..., which allows you to control the options in that dialog and others. This thread includes details on how to add back a 9.3 style Spatial Analyst menu, and this blog post includes some details on the change.
Best wishes,
Shaun
by Anonymous User
Not applicable
Original User: swalbridge
You'll also have to add a raster dataset into the map for the tools to become enabled -- they act on the currently selected layer.
cheers,
Shaun
AntoineSaurat
Dear Shaun,
Thank you for your message.
Although, activating the toolbar is not the problem, since I could activate it.
Here is what I have as a toolbar.
[ATTACH=CONFIG]25262[/ATTACH]
The only available functions are "create contour" and "create histogram".
So my question is: where are Spatial Analyst other functions, Menu and Options ?
Best regards,
Antoine
DanPatterson_Retired
Enable the extension then go to ArcToolbox, all the functionality has been moved there and the toolbar you are looking at is a former shell of itself
by Anonymous User
Not applicable
Original User: koenjinosora
I am very sorry if I am not clear, or maybe I lack knowledge,
...but,
what I want to access is the Spatial Analyst Options dialog box
[ATTACH=CONFIG]25263[/ATTACH]
this
and I don't see it in ArcToolBox...
ShaunWalbridge
Best wishes,
Shaun
by Anonymous User
Not applicable
Hello again Shaun
Thank you very much for your answer. I will try it.
