Export Web Map Changes From AGS 10.1 to AGS 10.1 SP1
1415
06-12-2013 08:48 PM
ShaunWeston
I'm experiencing an issue with the size of picture marker symbols using AGS 10.1 SP1 that didn't occur in AGS 10.1. For some reason, the picture marker symbols are appearing a lot larger in the printout than they should be and I did some testing and compared to AGS 10.1 with no service and there is a noticeable difference (see attached).
Compare ArcGIS10.1Print.jpg to ArcGIS10.1SP1Print.jpghttp://forums.arcgis.com/attachment.php?attachmentid=25237&stc=1&d=1371098769. You can see that the two orange signs are a lot bigger in SP1 export web map than they should be. The correct size is whats shown in "ArcGIS10.1Print.jpg". So just wondering what has changed between AGS 10.1 and 10.1SP1 to muck this up for me. This is basically a flex widget I have created to put picture marker symbols onto the map.
ShaunWeston
Just tested and this still occurs in ArcGIS Server 10.2
