AnsweredAssumed Answered
Define side of window/door ?
Question asked by geonetadmin on May 13, 2013
Latest reply on May 16, 2013 by geonetadmin
Original User: monrath.p
Hi!
I am working with CAD integration to make a floor plan. I would like to know that can CE define a side of window(Outside face or Inside face). For example I have a slide window that I slide to the right How to make sure that model that i generated the inside face of window will slide to the right.
For clearly understand. I will tell about the step that I am working.
1.I imported CAD to Arcmap and convert it to polygon
2.Define the type and attribute of each polygon. what is it floor,window, railing, door, stair etc.
[ATTACH=CONFIG]24266[/ATTACH]
3.I import it to CE and make a magic 2D floorplan become 3D floorplan
4.And now as the question Can CE define a side of window(Outside face or Inside face)?
[ATTACH=CONFIG]24267[/ATTACH]
For more information
I have 10 style of window and I can change by dynamic. For example pic
[ATTACH=CONFIG]24269[/ATTACH][ATTACH=CONFIG]24270[/ATTACH]
: For the style of window. I made it from facade wizard to make a complex split rule file and remove coding for UV texture. After that I combined rule file together with simple window rule.
[ATTACH=CONFIG]24271[/ATTACH]
: But there is a problem If the shape of window polygon have a different axes. It won't work. I have to use alignscopetoGeometry operation to make it work again.
Regards
Monrath P.
Outcomes
