Hello All,
I have historic aerial photos in TIFF format:
[ATTACH=CONFIG]24202[/ATTACH]
These display just fine (in State Plane)
The problem arises when I re-project them to UTM (NAD83) -> JP2 format (same with TIFF format too)
There is a dark area (some what resembling the extent).
[ATTACH=CONFIG]24203[/ATTACH]
When I set the display nodata value of 0 to NoColor, I get a tolerable image but still has some speckles in the collar area and holes inside (obviously 0 is a value).
[ATTACH=CONFIG]24204[/ATTACH]
During the re-projection process: I tried various methods - resampling, setting NoData, compression , etc. Evrytime it is the same result (dark around).
[ATTACH=CONFIG]24205[/ATTACH]
Am I missing something?
Is there a work-around?
Hello All,
Thanks for the responses.
Yes, I tried it
the black collar has the value 0. So display background set to Zero.
[ATTACH=CONFIG]24208[/ATTACH]
The problem some of the areas inside (valid) also have zero values. So holes are showing up while the collar is removed (minimized).
[ATTACH=CONFIG]24209[/ATTACH]
Seems to be the problem repeatedly for different datasets.
