AnsweredAssumed Answered
Map projection of BELGIUM - distorted. Please help
Question asked by Mountleek on May 2, 2013
Latest reply on May 2, 2013 by geonetadmin
Hello, I'm making a map of Belgium.
The problem is that every map of Belgium I have seen looks like this:http://postimg.org/image/fj5t91zvr/ [Belgium is quite "vertical".]. But the only thing I can do is this: http://postimg.org/image/va40wqdtl/ [Belgium is not "vertical" at all, it's rather "horizontal". It's distorted.]
Could you give me advice on how to change my map? I have ArcMap 10.1 trial version. I'm using this shapefile: http://leteckaposta.cz/841150880
In the Layer Properties, the Projected Coordinate System is Belge_Lambert_1972, the Geographic Coordinate System is GCS_Belge_1972. The Coordinate System in Data Frame Properties is Belge Lambert 1972.
Could you let me know, how exactly I can change this? Do I have to change the Projected or the Geographic or the Data Frame coordinate system. Which coordinate system should I choose for a "normal" map of Belgium? I'm very confused about this...
I would be happy for any help :)
Outcomes
