Converting 2D raster scanned map to DEM
2457
5
04-22-2013 02:32 AM
ConorCahalane
I tried two really great tools this weekend, ArcScan and TopoToRaster. They do exactly what im looking for, but i would like to improve the results a bit.
I downloaded a sample contour map off the net
http://www.ducklakeproperty.com/images/map/Moon_Pond_detail.jpg
then used ArcScan to make the contours into vectors giving me this image
[ATTACH=CONFIG]23700[/ATTACH]
im happy with it, even though i could probably tweak it a bit using the hole and gap settings - and then i run TopotoRaster giving me this greyscale  DEM.
[ATTACH=CONFIG]23701[/ATTACH]
but as you can probably see, the levels are off..it is coloured as lower when it should be higher and vice-versa. I'm guessing thats because the vector contours i used had no elevation field? The manual is a bit unclear - it seems to imply the contours are all you need, but surely you need a starting elevation? Do i need all elevations?
Any suggestions?
Conor.
DanPatterson_Retired
your lines do not have any elevations associated with them, hence, you won't be able to generate a DEM unless you can ascribe values to them
by Anonymous User
Not applicable
Original User: con20or
Thanks Dan.
I tried it with another map, a colour one with lots of symbology on it, it didnt do half as well. First i had to convert it to grayscale so I could assign the 2 classes in the symbology tab which lowered the quality quite a bit. I played around with the settings too, increased tolerance etc, but no luck.
ConorCahalane
Seems this is a tough one to do with any sort of thematic detail on the map. If the map is in colour, you have to convert it from RGB to greyscale before you can change the display properties to classified, so you lose some detial there. Then when you lower the number of classes to two, you lose lots more, particularly if there are thin contour lines. I tried selecting the contours in GIMP and then putting them in a seperate image, but the requirement for two classes only still caused problems.
Any suggestions?
by Anonymous User
Not applicable
Original User: erictrice
Why not just download a DEM for the area?  Or use the Esri World Elevation Services... I strongly urge you to discontinue your current methodology.
Best Regards,
Eric
ConorCahalane
Hi Eric,
It's old historical mapping - the topography has changed significantly since then, a modern DEM would be no good.
