Hello everybody, I am using a Dojo Gantt Chart in ArcGIS javaScript API3.3. and it seems that it does not work properly with the API3.3 popup menu which appears when you hover over the task or project; it pops up too far down. When I change the API to the 3.2 version everything works perfectly in the Gantt Chart. (Please see two attached images) I have also attached a zipped html document which shows this problem. This file was created using a Dojo Gantt Chart Example from http://dojotoolkit.org/reference-guide/1.8/dojox/gantt.html If you change version in the attached document from 3.3 to 3.2 you will see that Gantt Chart functions properly.
Can somebody help with this weird issue. Thank you in advance
