Original User: DanialRosenbalm
Do the 10.1 Add User / Manage Roles not work through an SDE application service connection?
When using a regular direct connection to our database, these tools work perfectly. When we attempt to use them with the SDE application service connection, they give an error message in the database connection input box. It states that this tool only works for oracle, sql server, and postgres databases.
Dan
Dan
From ESRI support:
[INDENT]At this point, this bug's status is stated to be "As Designed", so unfortunately, you will have to either use a direct connect or add the users or roles as you did in previous versions of the software.[/INDENT]
NIM082577 'Create Database User' tool fails when using Application server connection
Maybe this will be updated in a future patch or version.
Dan R
