I changed the values passed to esri.geometry.Extent. Instead of what you posted, I took the values from the default view of the map service here: http://www.geoiddata.com/arcgis/rest/services/Hawk/MapServer?f=jsapiSince that is a page built with the JS API, and the map is available via a global variable named "map", you can open the console and to this:
dojo.toJson(map.extent.toJson());
Which gives you:
"{"xmin":-11216835.021871055,"ymin":3398518.1829228727,"xmax":-10843258.104015714,"ymax":3553770.9280056115,"spatialReference":{"wkid":102100}}"
Remove the leading and trailing double quotes and you can pass that to esri.geometry.Extent, as shown in the link I posted initially.
