AnsweredAssumed Answered
Quick Import - "unexpected execution path" error message on CAD (.dwg) file
Question asked by geonetadmin on May 21, 2012
Original User: ramakan
I am trying to use Quick Import to bring in a CAD .dwg file into ArcMap. The tool scans all the records, then fails with the error "unexpected execution path". (see first attached image).  I can otherwise load this CAD file in ArcMap using the Interchange file (.e00) conversion tool, but some arcs are not coming in correctly this way, so I am trying to see what the results are with Quick Import.
I am also reproducing the log and prm files generated by the process in Application Data\Safe Software\Interoperability\logs.
I can send the CAD file by email since the forum will not allow me to attach it.
[ATTACH=CONFIG]14486[/ATTACH]
[ATTACH=CONFIG]14487[/ATTACH]
Here is the log file:
2012-05-17 09:26:29|   0.1|  0.1|INFORM|Opening E00 reader for dataset \\isr04\isgeoshare\Projects\Land_Migration\Process\source_data\streets\stclinenad27.e00
2012-05-17 09:26:29|   0.1|  0.0|INFORM|Opening GEODATABASE_FILE writer for dataset c:\temp\stcli.gdb
2012-05-17 09:26:29|   0.2|  0.1|INFORM|Loaded module 'GEODATABASE_FILE' from file 'C:\Program Files\ESRI\Data Interoperability Extension\GEODATABASE9.dll'
2012-05-17 09:26:29|   0.2|  0.0|INFORM|FME API version of module 'GEODATABASE_FILE' matches current internal version (3.6 20090807)
2012-05-17 09:26:29|   0.2|  0.0|INFORM|FME Configuration: No destination coordinate system set
2012-05-17 09:26:29|   0.2|  0.0|INFORM|Reading schema features
2012-05-17 09:26:29|   0.2|  0.0|INFORM|Opened E00 File //isr04/isgeoshare/Projects/Land_Migration/Process/source_data/streets/stclinenad27.e00 for input
2012-05-17 09:26:29|   0.2|  0.0|INFORM|Opened CAT Definition File `C:\Program Files\ESRI\Data Interoperability Extension\e00\e00.def' for input
2012-05-17 09:26:29|   0.2|  0.0|INFORM|CAT Definition File C:\Program Files\ESRI\Data Interoperability Extension\e00\e00.def successfully parsed
2012-05-17 09:26:29|   0.2|  0.0|INFORM|E00 coverage file `//isr04/isgeoshare/Projects/Land_Migration/Process/source_data/streets/stclinenad27.e00' was originally called `K:\Projects\Land_Migration\New_Land\ProtoTypes_93\stclinenad27_.e00'
2012-05-17 09:26:37|   1.3|  1.1|WARN  |Could not find a coordinate system for ZONE 202; substituting 'AZ-C', whose FIPSZONE matched specified zone
2012-05-17 09:26:54|   4.9|  3.6|INFORM|Merged 8 schema features read from 1 datasets into 8 resulting feature types
2012-05-17 09:26:54|   4.9|  0.0|INFORM|Read 8 schema features
2012-05-17 09:26:54|   4.9|  0.0|INFORM|Reading features
2012-05-17 09:26:54|   4.9|  0.0|INFORM|Using E00 Reader $Revision: 64208 $ ( $Date: 2009-10-09 17:28:39 -0700 (Fri, 09 Oct 2009) $ ) to read e00 data from file `\\isr04\isgeoshare\Projects\Land_Migration\Process\source_data\streets\stclinenad27.e00'
2012-05-17 09:26:55|   4.9|  0.0|INFORM|Opened E00 File \\isr04\isgeoshare\Projects\Land_Migration\Process\source_data\streets\stclinenad27.e00 for input
2012-05-17 09:26:55|   4.9|  0.0|INFORM|Opened CAT Definition File `C:\Program Files\ESRI\Data Interoperability Extension\e00\e00.def' for input
2012-05-17 09:26:55|   4.9|  0.0|INFORM|CAT Definition File C:\Program Files\ESRI\Data Interoperability Extension\e00\e00.def successfully parsed
2012-05-17 09:26:55|   4.9|  0.0|INFORM|E00 coverage file `\\isr04\isgeoshare\Projects\Land_Migration\Process\source_data\streets\stclinenad27.e00' was originally called `K:\Projects\Land_Migration\New_Land\ProtoTypes_93\stclinenad27_.e00'
2012-05-17 09:27:02|   6.0|  1.1|WARN  |Could not find a coordinate system for ZONE 202; substituting 'AZ-C', whose FIPSZONE matched specified zone
2012-05-17 09:27:02|   6.0|  0.0|INFORM|FME Configuration: Source coordinate system for reader R_1[E00] set to `AZ-C' as read from input data
2012-05-17 09:27:04|   7.0|  1.0|INFORM|Coordinate System `AZ-C' parameters: CS_NAME=`AZ-C' DESC_NM=`NAD27 Arizona State Planes, Central Zone(202), US Foot' DT_NAME=`NAD27' EPSG=`26749' GROUP=`SPCS27' MAP_SCL=`1' ORG_LAT=`31' PARM1=`-111.916666666667' PROJ=`TM' QUAD=`1' SCL_RED=`0.9999' SOURCE=`Snyder, J.P., 1987, Map Projections - A Working Manual' UNIT=`FOOT' X_OFF=`500000'
2012-05-17 09:27:04|   7.0|  0.0|INFORM|Coordinate System `AZ-C' as OGC Well Known Text: PROJCS["NAD27 Arizona State Planes, Central Zone(202), US Foot",GEOGCS["NAD27",DATUM["North_American_Datum_1927",SPHEROID["Clarke 1866, Benoit Ratio",6378206.4,294.9786982139006,AUTHORITY["EPSG","7008"]],AUTHORITY["EPSG","6267"]],PRIMEM["Greenwich",0],UNIT["degree",0.0174532925199433],AUTHORITY["EPSG","4267"]],PROJECTION["Transverse_Mercator"],PARAMETER["latitude_of_origin",31],PARAMETER["central_meridian",-111.916666666667],PARAMETER["scale_factor",0.9999],PARAMETER["false_easting",500000],PARAMETER["false_northing",0],UNIT["U.S. Foot",0.3048006096012192],AUTHORITY["EPSG","26749"]]
2012-05-17 09:27:04|   7.0|  0.0|INFORM|Using Dynamic Writer $Revision: 26873 $ ( $Date: 2006-03-01 10:08:47 -0800 (Wed, 01 Mar 2006) $ ) with module GEODATABASE_FILE to write dataset `c:\temp\stcli.gdb'
2012-05-17 09:27:04|   7.0|  0.0|INFORM|FME API version of module 'GEODATABASE_FILE' matches current internal version (3.6 20090807)
2012-05-17 09:27:04|   7.1|  0.1|INFORM|FME API version of module 'GEODATABASE_FILE' matches current internal version (3.6 20090807)
2012-05-17 09:27:04|   7.1|  0.0|INFORM|This Geodatabase Reader/Writer module has been built using ArcGIS 9 libraries
2012-05-17 09:27:04|   7.1|  0.0|INFORM|An ArcGIS license is already checked out. The product checked out is 'ArcInfo'
2012-05-17 09:27:08|   7.4|  0.4|INFORM|Created and connected to the ArcGIS 10.0 File Geodatabase at 'c:\temp\stcli.gdb'
2012-05-17 09:27:08|   7.4|  0.0|INFORM|All errors encountered while writing features will be ignored as directed by the '_IGNORE_FAILED_FEATURE_ENTRY' keyword
2012-05-17 09:27:08|   7.5|  0.0|INFORM|The 'HAS_Z_VALUES' keyword is set to 'AUTO_DETECT'. With the exception of MultiPatch feature classes, the dimensionality of new feature classes will be based on the first feature written to the feature class. (Features with no geometry are considered 2D)
2012-05-17 09:27:08|   7.5|  0.0|INFORM|A default z-value of '0' will be used for all 3D features where z-values are not provided
2012-05-17 09:27:08|   7.5|  0.0|INFORM|Geodatabase Writer: Not simplifying geometries being written to the Geodatabase
2012-05-17 09:27:08|   7.5|  0.0|INFORM|Writer mode is 'INSERT'
2012-05-17 09:27:09|   7.5|  0.1|INFORM|Transactions are being used by the Geodatabase Writer
2012-05-17 09:27:09|   7.5|  0.0|INFORM|FME Configuration: Destination coordinate system set to input coordinate system `AZ-C'
2012-05-17 09:27:09|   7.5|  0.0|ERROR |Unexpected execution path. Please contact Safe Software
2012-05-17 09:27:09|   7.5|  0.0|ERROR |A fatal error has occurred. Check the logfile above for details
2012-05-17 09:27:09|   7.5|  0.0|STATS |GeodatabaseRelationshipFeaturesPipeline::GeodatabaseRelationshipFeatures(SortFactory): Sorted 0 feature(s)
2012-05-17 09:27:09|   7.5|  0.0|INFORM|Transaction #1 (final transaction) was successfully committed
2012-05-17 09:27:09|   7.5|  0.0|INFORM|Closing the Geodatabase writer
2012-05-17 09:27:09|   7.5|  0.0|INFORM|=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-
2012-05-17 09:27:09|   7.5|  0.0|INFORM|Feature output statistics for `GEODATABASE_FILE' writer using keyword `W_1':
2012-05-17 09:27:09|   7.5|  0.0|STATS |=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-
2012-05-17 09:27:09|   7.5|  0.0|STATS |                               Features Written
2012-05-17 09:27:09|   7.5|  0.0|STATS |e00_arcdef        1
2012-05-17 09:27:09|   7.5|  0.0|STATS |==============================================================================
2012-05-17 09:27:09|   7.5|  0.0|STATS |Total Features Written                                                       1
2012-05-17 09:27:09|   7.5|  0.0|INFORM|FME Session Duration: 40.3 seconds. (CPU: 5.5s user, 2.1s system)
2012-05-17 09:27:09|   7.5|  0.0|INFORM|END - ProcessID: 5160, peak process memory usage: 133488 kB, current process memory usage: 102932 kB.
Here is the .prm file associated with the log file:
[session]
[constraints]
[source]
gentrans_format = E00
gentrans_dataset = \\isr04\isgeoshare\Projects\Land_Migration\Process\source_data\streets\stclinenad27.e00
RUNTIME_MACROS = METAFILE,e00raw,TEXT_CURVE,<Unused>,INCLUDE_BND,<Unused>,INCLUDE_TIC,<Unused>,GENERATE_NODE_FEATURES,<Unused>,_MERGE_SCHEMAS,YES
META_MACROS = SourceMETAFILE,e00raw,SourceTEXT_CURVE,<Unused>,SourceINCLUDE_BND,<Unused>,SourceINCLUDE_TIC,<Unused>,SourceGENERATE_NODE_FEATURES,<Unused>
METAFILE = e00raw
COORDSYS =
IDLIST =
[destination]
gentrans_format = GEODATABASE_FILE
gentrans_dataset = c:\temp\stcli.gdb
HAS_Z_VALUES = auto_detect
DEFAULT_Z_VALUE = 0
ENV_MGR_FILE = C:\DOCUME~1\jdeclet\LOCALS~1\Temp\FME_a00304
OVERWRITE_GEODB = yes
IGNORE_FAILED_FEATURE_ENTRY = YES
MAX_NUMBER_FAILED_FEATURES = -1
I can  provide the CAD DWG file if necessary.
Cordially,
Juan Declet-Barreto
City of Mesa, Arizona
Outcomes
