sderaster command giving error
714
05-14-2012 01:54 PM
by Anonymous User
Not applicable
Original User: Rowena
I am attempting to run the sderaster import command from a bat file.
System:
ArcGIS 10 SP4
SQL Server 2008
Command:
sderaster -o import -l HillshadeColour,image -f colourhillshade.tif -g -c lz77 -I nearest -N -G file=alb2.prj -L 0 -s servername -i sde:sqlserver:servername -D database -u username -p password
Error:
SE_table_create (-453) Database user name and current user schema do not match. Incomplete....
Can someone shed some light on this? The username and schema name are the same.
by Anonymous User
Not applicable
Figured it out about 5 minutes after I posted the questions... I hadn't set the Default Schema of the user.
by Anonymous User
Not applicable
