AnsweredAssumed Answered
Mosaic Dataset _ methods and problems
Question asked by dasmy004 on Mar 7, 2012
Latest reply on Feb 3, 2015 by r.schuepferlingesri-de-esridist
Hi All,
I am created a mosaic of 20 Geoeye-1 images.
they are acquired over three different dates (3 to 9 months apart)
I used the following methodology to mosaic them
1- clip nodata, zero values, cloud cover, and water portions
2- mosaic images from the same date (three mosaic dataets)
3- create geodatabase
4- create new empty mosaic dataset
5- add images to the mosaic dataset
6- edit footprints
6- build and edit seamlines
7- build boundary
9- run 'color balance tool'
8- generate overview
9- export to raster
the mosaic looked acceptable but I faced the following problems.
A)when I mosaic pan-sharpened images I get very bad color balance
if the raw ms images are mosaiced the color balance is good or acceptable
B) there is a shift between some images in the mosaic. it exists in some parts and not in others.
[ATTACH=CONFIG]12469[/ATTACH]
C) when exporting the mosaic to .img, .tif other formats the image quality is reduced, and noisy image is prodcued.
some times the noise is higher at lower scales, when zooming in it is reduced.
D) pixilation occures in some parts of the image. usually from the images at the end of mosaic. these white pixels has nodata in the red band only. see the examples below.
[ATTACH=CONFIG]12470[/ATTACH]
[ATTACH=CONFIG]12471[/ATTACH]
Thanks a lot and sorry about the long post
Mohammad
Outcomes
