AnsweredAssumed Answered
Vegetation Perpendicular Distance Index
Question asked by geonetadmin on Feb 11, 2012
Latest reply on Feb 12, 2012 by tereshenkov
Original User: edi1511
Does anyone have a tool or arcpy script for calculating the Vegetation Perpendicular Distance Index from satellite imagery such as SPOT, Landsat or MODIS?
I need to calculate indices of the spectral distance the vegetation reflectance is away from the soil reflectance.
The published method is to use ERMapper to create the scattergrams from which you can get the slope, intercept and Perp Dist variables and then plug them into the ERMapper algorithm for Vegn Perp Dist, select the bands and out comes the result. Well that works but ERMapper won't allow me to save the resulting virtual file. Can visualise it but can't saev it.
Why explain this. As an alternative I built an ArcTool (using Raster Calculator) that should do the same thing as the Vegn Perp Dist Algorithm. Just rewrote the same formulae from ERMapper in Raster Calculator. Copy attached.
Won't work. Can't work out how to fix.
Here is formulae:
Abs((((-1 * (Raster(r"sc2_box_landsat_20051126.img - Layer_2") * 1.3033)) + Raster(r"sc2_box_landsat_20051126.img - Layer_3") - 24.569) / (SquareRoot((1.3033 * 1.3033) + 1))) * 254 /25.91)
Here is error message:
ERROR 000539: Error running expression: rcexec() <type 'exceptions.RuntimeError'>: No CellSize and Extent set
Failed to execute (Raster Calculator).
How do I satisfy the rrequirement to "set a cell size and extent"? It seems to me these are set by the image input bands. They are fairly small, Extent is 760 columns by 520 rows and cell size is 25m. All defined in the image band properties. Tried it with 16 bit and 8 bit unsigned data. Still no go.
Any Model Builders expert advice would be very much appreciated.
Thank you very much.
edi1511
Outcomes
