AnsweredAssumed Answered
�??Table to Domain�?� command with �??Append�?� as an �??Update�?� option
Question asked by Jamal432@gmail.com on Jan 16, 2012
I have a geodatabase (attached) with a domain named D1 that takes the values A, B, C (screenshot1).
[ATTACH=CONFIG]11191[/ATTACH]
I wanted to import a new values for the domain D1 from an excel table (attached). I used the command �??Table to domain�?� with an option �??Append�?� to import the column with a header named �??D1�?� from the excel file E and Sheet S1. This column contains the values B, C, D. I got the error shown in the screenshot below
[ATTACH=CONFIG]11192[/ATTACH], [ATTACH=CONFIG]11193[/ATTACH]
What is supposed to happen to the domain named �??D1�?�? I expected that the new values of the domain �??D1�?� will will be: A, B, C and D! but that didn�??t take place!
Then what is the critical difference between �??Replace�?� and �??Append�?� options when using the command �??Table to Domain�?�?
Thank you in advance,
Regards
Jamal
Outcomes
