Coordinates Transformation Issue
589
11-14-2011 03:47 PM
DmitriyNikolaev
Hi ESRI and all,
I am not sure if this is a proper forum but...
I think I have an important question to ask and I am sure that sharing this information will be a great benefit to everyone.
I have discovered a huge spatial difference in results when reprojecting data (project command) using different transformation methods available from the standard ESRI transformation list.
This is what I have done in ArcGIS10.
I have generated a point, which is located in Papua New Guinea using GDA94 MGA Zone56 coordinate system.
I have projected original point to AGD66 Zone56 using NTv2 transformation and my output point is shifted only about 1m from the original location, which is a bit suspicious as I know that the difference between AGD66 and GDA94 in Papua New Guinea should be about 180m-200m.
Also I have projected the original point to AGD66 Zone56 using
AGD_1966_To_GDA_1994
AGD_1966_To_GDA_1994_2
AGD_1966_To_GDA_1994_3
AGD_1966_To_GDA_1994_4
And all my results are significantly spatially distributed (far away from each other). For instance the difference between AGD_1966_To_GDA_1994_2 and AGD_1966_To_GDA_1994_3
transformation results is about 17 metres!
Is anybody out there can explain me what is going wrong with my transformations? I am aware that all transformations are supposed to produce slightly different results but 17m... I think it is too much.
I have attached an illustration for a better understanding of this issue and the original point as a shapefile.
D
by Anonymous User
Not applicable
Original User: csny490
Not sure about the mathematical accuracy of the transformation methods, but here's the resource I use: http://support.esri.com/en/knowledgebase/techarticles/detail/21327
