I have to write a C code which will accept polygon features and create a buffer around them and store this buffer feature in a new feature of polygon type.
I am aware of the ArcSDE C API and I believe that this requirement can be completed through SE_shape_generate_buffer. But as per my code I am unable to create a buffer around the feature, instead of this buffer its copy and store the same feature in the output but the difference is that this new feature is tilted upwards.
Can anyone please help me and provide me some kind of support to complete this functionality. Please find below the code I have applied ...
char tps_trt[15];
char tps_trt_tuple[15];
time_t time_deb;
time_t time_deb_tuple;
time_t time_cour;
long featurecount = 0;
long result = 0;
long resultat=0;
long resultat1=0;
long lNumPoints=0;
long rc=0;
long fdp_db_rec=0;
long l_layerType=SE_AREA_TYPE_MASK|SE_MULTIPART_TYPE_MASK;
char pch_log[LG_MAX_ARG+1];
prim_shapes=(SE_SHAPE*)malloc(sizeof(SE_SHAPE)*MAX_SHAPES);
sec_shapes=(SE_SHAPE*)malloc(sizeof(SE_SHAPE)*MAX_SHAPES);
fdp_db = (SE_SHAPE *) malloc (sizeof (SE_SHAPE)* MAX_FDP_DB_RECORDS);
new_couv_shapes=(SE_SHAPE*)malloc(sizeof(SE_SHAPE)*MAX_SHAPES);
tab_coordRef=(SE_COORDREF*)malloc(sizeof(SE_COORDREF)*MAX_COORDREF);
long size_SE_SHAPE=sizeof(SE_SHAPE)*1;
/* DEBUT Initialisation du tuple */
enreg * tuple=(enreg*)malloc(sizeof(enreg));
ccf_initConnection_SDE(&tab_connections[0],psde_error, con_server, con_instance, con_dbase, con_user, con_pswd);
ccf_init_stream_SDE (0, &tab_connections[0],psde_error, &tab_streams[0], &tab_coordRef[0], &tab_layers[0],&tab_sqlConstruct[0], nomLayerIn, clauseWhere, NULL,l_layerType,tuple);
ccf_init_stream_SDE (1, &tab_connections[0],psde_error, &tab_streams[1], &tab_coordRef[1], &tab_layers[1],NULL, nomLayerOut, NULL, 0,l_layerType,tuple);
rc=SE_layerinfo_get_shape_types (tab_layers[0], (LONG *) &l_layerType);
long l_nbTuples = 0,ret_shapes=0;
long nb_mailles_20x20=0;
long countShapes=0;
BOOL isDisjoint_ret=TRUE;
char * var;
while ((resultat1=ccf_lire_tuple_SDE(psde_error, &tab_streams[0], tuple, &prim_shapes, &tab_coordRef[0])) == 0)
ccf_majTuple(tuple);
ret_shapes= SE_shape_generate_buffer (prim_shapes, 0.5, 30 , &new_couv_shapes);
tuple->tab_valChampsOut[0]=(char*) &(new_couv_shapes[0]);
ccf_ecrire_tuple_SDE (psde_error, &tab_streams[1], &tab_layers[1], tuple,&tab_coordRef[1]);
ccf_commit_SDE(&tab_connections[0],psde_error,&tab_streams[1]);
SE_shape_free(new_couv_shapes);
I have also reffer below mention link and tried to implement this code but didnt got any success.
http://edndoc.esri.com/arcsde/9.0/capi_concepts/shape_functions.htm
Please find attached images of output I got from this.
char tps_trt[15];
time_t time_deb;
time_t time_cour;
long result = 0;
long resultat=0;
long resultat1=0;
long lNumPoints=0;
long rc=0;
long fdp_db_rec=0;
long countShapes=0;
char * var;
In order to get help with your code, you need to post it (not just the function which calls that code).
The code you did post has questionable use of array allocation (with no obvious need for arrays
and undefined MAX_* macros). All the code that contains "long" is incorrect -- ArcSDE uses the
"LONG" macro to hide the implementation of "long" on 32-bit platforms and "int" on 64-bit, so
using "long" can cause alignment issues that randomize results. From a 'C' coding standpoint,
you should *NEVER* cast the results of malloc (doing so should be unnecessary, and hides
possible warnings or errors which would be returned by the compiler).
The function which would perform a Cartesian buffer on a shape should probably look like this
(once they get the fixed-width CODE font straightened out):
But you need quite a bit of validation code to make sure the coordinate references in the
source and destination layers are identical.
I strongly suggest you review the way you're using pointers and arrays, because the casting
you're doing between SE_SHAPE and char * is not valid and your SE_shape_free invocation
is likely to corrupt memory.
- V
