Original User: jaykayone
Dear INSPIRE Team,
I've installed ArcGIS for INSPIRE and I have the following problem:
When I click "Add INSPIRE Layer", I choose my Geodabase.
The program runs a quick analysis and shows me an empty list of INSPIRE Layers.
The GDB Template has been successfully loaded into an Enterprise Geodatabase. The FCs and Tables are registered as versioned with the "Move edits to base" option.
The DBMS used is Postgresql 8.3 on 64bit Linux. The geodatabase works fine and can be edited with the standard ArcMAP Functions.
Why can't the ArcMap Addin find the INSPIRE Layers?
Can it be related to the PostgreSQL prefixes (Feature Class: inspire.inspire.auAdmUnitS)?
Thanks in advance
Jeff
Dear INSPIRE Team,
Thanks in advance
Jeff
If Feature class has no data it won't appear in "Add Inspire Layers" wizard.
