Pre-Logic Script Code: def nullToBlank(fieldValue): if fieldValue == None: return ' ' # returns a string with just a space in it (looks blank). else: return fieldValue Expression: nullToBlank(!oldField!)
By 'blank' you mean...? It also depends on the data type of your field. The easy way: if your field is a string you can do the following in a field calculator (to be safe: create a new field, then use this to get the values into it, then delete the old field; but you can just have the field calculate on itself):Pre-Logic Script Code: def nullToBlank(fieldValue): if fieldValue == None: return ' ' # returns a string with just a space in it (looks blank). else: return fieldValue Expression: nullToBlank(!oldField!)
The hard way would be to make a Python script that iterates through all the rows (using UpdateCursor) and replaces the values that are == None with something...
#One way... txtFieldList = arcpy.ListFields(myFC, "", "STRING") updateRows = arcpy.UpdateCursor(myFC) for updateRow in updateRows: for txtField in txtFieldList: if updateRow.isNull(txtField.name): updateRow.setValue(txtField.name, '') updateRows.updateRow(updateRow) del updateRow, updateRows
#Another way that might? be faster/better: txtFieldList = arcpy.ListFields(myFC, "", "STRING") for txtField in txtFieldList: updateRows = arcpy.UpdateCursor(myFC, txtField.name + " IS NULL", "", txtField.name) for updateRow in updateRows: updateRow.setValue(txtField.name, '') updateRows.updateRow(updateRow) del updateRow, updateRows
Didn't test it, but this code should "blank-ify" any NULL text fields:#One way... txtFieldList = arcpy.ListFields(myFC, "", "STRING") updateRows = arcpy.UpdateCursor(myFC) for updateRow in updateRows: for txtField in txtFieldList: if updateRow.isNull(txtField.name): updateRow.setValue(txtField.name, '') updateRows.updateRow(updateRow) del updateRow, updateRows#Another way that might? be faster/better: txtFieldList = arcpy.ListFields(myFC, "", "STRING") for txtField in txtFieldList: updateRows = arcpy.UpdateCursor(myFC, txtField.name + " IS NULL", "", txtField.name) for updateRow in updateRows: updateRow.setValue(txtField.name, '') updateRows.updateRow(updateRow) del updateRow, updateRows
