AnsweredAssumed Answered
ArcGIS 10 MapControl Dynamic Display Problem
Question asked by geonetadmin on Jul 11, 2011
Original User: itaibh
I'm trying to convert an ArcGIS 9.3 .NET application that displays a map control with dynamic display  enabled to ArcGIS 10.
It seems that once I enable dynamic display, instead of seeing the map content on the entire map control area, it displays in a small rectangle on the upper left corner. The rest of the control area display smudges:
This also happens if there is no dynamic layer. The only thing that matters is that dynamic display is enabled. Once I disable dynamic display it looks fine.
The same application worked fine with ArcGIS 9.3.1.
What can I do to try to fix it?
Update: The smudges appear when I try to resize the control. It seems like the OpenGL context is not being set to the correct size. Any idea how to fix that? Is it a bug in the new ArcMap version?
Update 2: I attached a sample project demonstrating that issue.
Outcomes
