AnsweredAssumed Answered
True transparency requested for MXD-based services
Question asked by geonetadmin on Jun 20, 2011
Original User: vdkamp
Based on the ArcGIS Flex API, we have developed client software which communicates with a MXD-based ArcGIS service. Through other (SOAP) services the client has access to the fine-grained ArcGIS objects allowing layer properties to be modified.
One of these modifiable properties is the layer transparency. However, because the MXD-based service does not support PNG32, layers will not be transparent in the client when displayed on top of another map service layer. Using a MSD-based service (which supports PNG32) is not an option because then we don't have access to the ArcObjects.
Is there a particular reason why PNG32 is not supported and is there any change that it will be supported in the future (because we really need true transparency)?
Regards,
Albert van der Kamp
Outcomes
