I managed to find a thread on StackOverflow that solved my problem http://stackoverflow.com/questions/3904389/adding-multiple-field-names-in-arcgis-using-python.The solution using python was to replace infields = arcpy.GetParameterAsText(1)with infields = arcpy.GetParameterAsText(1).split(',')then add the followingfor i in range(len(infields)):Then the entire script is embedded within the for loop.The len() function finds the length of the list.-Tom Dilts
