Original User: helenchu
All,
I have Error HRESULT E_FAIL has been returned from a call to a COM component when trying to set a edit target layer. Below is what I have (vs2008, addin button). I could get the msgbox to show the FeatureLayerName fine then it throws error at the 'exit for'. I tried to create a new clean mxd application, didn't fix it. I looked everywhere but couldn't find a solution. These line of codes worked in my vb 6.0 with a few changes. In vb 6.0 I passed pApp as AppRef not as IApplication & pMap = pEditor.Map
Any help is greatly appreciated.
Public Function setTargetLayer(ByVal strLayerName As String, ByVal pApp As ESRI.ArcGIS.Framework.IApplication) As IFeatureLayer
Dim i, z As Integer
Dim pMap As IMap
Dim pComLayer As ICompositeLayer
Dim pLayer As ILayer
Dim pFlayer As IFeatureLayer
Dim pEditLayers As IEditLayers
Dim pUID As New UID
Dim pEditor As IEditor
Dim pDoc As IMxDocument
pUID.Value = "esriEditor.Editor"
pEditor = pApp.FindExtensionByCLSID(pUID)
pDoc = pApp.Document
pMap = pDoc.FocusMap
pEditLayers = pEditor
Try
'Set Target Layer
For i = 0 To pMap.LayerCount - 1
If TypeOf pMap.Layer(i) Is IFeatureLayer Then
pLayer = pMap.Layer(i)
If UCase(pLayer.Name) = UCase(strLayerName) Then
If pEditLayers.IsEditable(pLayer) Then
pFlayer = pLayer
setTargetLayer = pFlayer
MsgBox(FeatureLayerName:" & pFlayer.Name)
Exit For
Else
MsgBox("this layer is not editable")
Exit Function
End If
End If
Else
If TypeOf pMap.Layer(i) Is ICompositeLayer Then
pComLayer = pLayer
For z = 0 To pComLayer.Count - 1
If UCase(pComLayer.Layer(z).Name) = UCase(strLayerName) Then
If pEditLayers.IsEditable(pComLayer.Layer(z)) Then
pFlayer = pComLayer.Layer(z)
Exit For
Else
MsgBox("This layer is not editable")
Exit Function
End If
End If
Next z
End If
End If
Next i
Catch ex As Exception
System.Windows.Forms.MessageBox.Show(ex.Message)
End Try
End Function
