chrislott
ArcCatalog v10 Internet Explorer Script Error on page, Run ActiveX control
Discussion created by chrislott on Aug 16, 2010
Latest reply on Mar 23, 2016 by Matiss
I'm struggling mightily with the new ArcCatalog version 10.
When I try to use basic features from ArcCatalog I get
lots of dialogs "error on page" and have to click "Run active X control"
repeatedly.  It's extremely frustrating.
Here's one way to reproduce the problem I'm seeing.
1. Establish a connection to some geodatabase.
2. Right-click on that connection and pick Import, then Feature Class
(single).
3. In the "Feature Class to Feature Class" dialog, click on the
   button "Environments...".
   The result for me is a new dialog:
     An error has occurred in the script on this page.
     Line: 131
     Char: 4
     Error: Invalid pointer
     Code: 0
     URL:  file:///C:/Documents%20and%20Settings/clott/Application%20Data/ESRI/Desktop10.0/ArcToolbox/Dlg/MdDlgContent.htm
     Do you want to continue running scripts on this page?
    Anyhow I click "Yes".
    At the top of the Environment Settings dialog I now see "This
    website wants to run the following add-on: 'ArcGIS Product Version
    Library' from 'ESRI (unverified publisher)'.  If you trust the
    website and the add-on and want to allow it to run, click here..."
    Heck I wasn't aware I was visiting a web site.  Anyhow I click there
    and pick "Run ActiveX control", then a new dialog pops up "Internet
    Explorer - Security Warning" and on that dialog I click the Run
    button.
    Then the dialog "Internet Explorer Script Error" reappears and I go
    thru the whole process again.  I did this about 10 times then gave
    up, I'm not an infinite loop processor.  Does the process ever end?
I am working on a Windows XP machine with the Internet Options security
setting to "Medium High" which I suspect has to be scaled WAY back.
Anyone else?  Did I miss a critical note in the installation directions?
Outcomes
