Hello
I've been working on this off and on for the past 3 weeks so I thought I'd try to forum for some answers. It's not that complicated of a problem.
I have a model that I've attached to this message. In this model I have a custom script. The script is called "MergeFolder" and I have copied and pasted it below. It merges all shapefiles in one folder into a single shapefile. I am using Arc9.3 and the folder contains all line shapefiles.
What I've been having problems is accepting user input for assigning the input folder and the output merged shapefile. I know the use of arguments will solve this but how specifically can I do this? How can I change the script to accept user input? In the model, I changed the script properties to the attachments below (inFolder & outShp). Are the properties correct?
## Merge multiple shapefiles from a single directory.
# Import modules and create the geoprocessor object
try:
# 9.2 and beyond
import arcgisscripting, sys, os
gp = arcgisscripting.create()
except:
# 9.1 and before
import win32com.client, sys, os
gp = win32com.client.Dispatch("esriGeoprocessing.GpDispatch.1")
# Set the current workspace so the list has full paths
gp.workspace = os.getcwd()
# Start a blank list for appending
bList = []
# For each file in the current directory
for file in os.listdir(''):
# Get only the shapefiles
if (file.endswith(".shp")):
# Append all the files together into one big list
filepath = bList.append(file)
# Hard-code the output merged shapefile name
shapefile = "Merged.shp"
# Given a list of shapefiles, separate each by a ";"
# and put quotes around the whole thing
def shpList(filepath):
return '"%s"' % ';'.join(bList)
# Set the variable "mergedlist" to the newly formatted list of shapefiles
mergedlist = shpList(filepath)
try:
print "\nMerging " + mergedlist + " to get " + shapefile + "...\n"
gp.merge_management(mergedlist, shapefile)
print gp.getMessages()
except:
print "\n *** ERROR: Shapefiles failed to merge *** \n"
print "\nDone."
Thank you
