AnsweredAssumed Answered
ServiceError with Code 400 but no error message.
Question asked by geonetadmin on Oct 10, 2010
Latest reply on Jan 17, 2011 by geonetadmin
Original User: Mathias Westin
When running the sample code in the PDF-File in the zip I get a ServiceError with error code 400 stacktrace:
   at ESRI.ArcGIS.Client.Layer.OnInitializationFailed(EventArgs e)
   at ESRI.ArcGIS.Client.Layer.Initialize()
   at ESRI.ArcGIS.Client.ArcGISTiledMapServiceLayer.<>n__FabricatedMethod4()
   at ESRI.ArcGIS.Client.ArcGISTiledMapServiceLayer.<>c__DisplayClass2.<MapServiceInfoInitFailed>b__0()
   at System.Reflection.RuntimeMethodInfo.InternalInvoke(RuntimeMethodInfo rtmi, Object obj, BindingFlags invokeAttr, Binder binder, Object parameters, CultureInfo culture, Boolean isBinderDefault, Assembly caller, Boolean verifyAccess, StackCrawlMark& stackMark)
   at System.Reflection.RuntimeMethodInfo.InternalInvoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture, StackCrawlMark& stackMark)
   at System.Reflection.MethodBase.Invoke(Object obj, Object[] parameters)
   at System.Delegate.DynamicInvokeOne(Object[] args)
   at System.MulticastDelegate.DynamicInvokeImpl(Object[] args)
   at System.Delegate.DynamicInvoke(Object[] args)
   at System.Windows.Threading.DispatcherOperation.Invoke()
   at System.Windows.Threading.Dispatcher.Dispatch(DispatcherPriority priority)
   at System.Windows.Threading.Dispatcher.OnInvoke(Object context)
   at System.Windows.Hosting.CallbackCookie.Invoke(Object[] args)
   at System.Windows.Hosting.DelegateWrapper.InternalInvoke(Object[] args)
   at System.Windows.RuntimeHost.ManagedHost.InvokeDelegate(IntPtr pHandle, Int32 nParamCount, ScriptParam[] pParams, ScriptParam& pResult)
5. In the content panel (Grid) add a Map and layer:
<Grid x:Name="ContentGrid" Grid.Row="1">
<esri:Map >
<esri:ArcGISTiledMapServiceLayer
Url="http://services.arcgisonline.com/ArcGIS/rest/services/World_Str
eet_Map/MapServer" />
</esri:Map>
</Grid>
Seems to be because of the line break in the PDF-file, workes when I remove it. Would have been great with a error message like "Invalid URL"...
Outcomes
