Hey Daniel,Looks like the bug is in the TOC component(TOC.as) on how it reacts to map.reorder(). The problem is the LayerListWidget/TOC deals with just the "operational layers", while the reorder takes into account all the layers on the map causing the mismatch in the order.Try replacing the onLayerReorder() in TOC.as with:
private function onLayerReorder(event:MapEvent):void
var layer:Layer = event.layer;
var index:int = event.index;
var i:int;
var currentTOCIndex:int;
var currentItem:Object;
if (index <= (map.layerIds.length - _tocRoots.length)) // move this item to the bottom of toc
// index of item to move
currentTOCIndex = getCurrentTOCIndex();
// item to move
currentItem = _tocRoots.getItemAt(currentTOCIndex);
for (i = currentTOCIndex; i < _tocRoots.length; i++)
if(i == _tocRoots.length - 1)
_tocRoots.setItemAt(currentItem, _tocRoots.length - 1);
else
_tocRoots.setItemAt(_tocRoots.getItemAt(i+1), i);
else if ((map.layerIds.length - _tocRoots.length) < index < map.layerIds.length)
// item to move
var newTOCIndex:Number = map.layerIds.length - index - 1;
if (newTOCIndex < currentTOCIndex)
for (i = currentTOCIndex; newTOCIndex <= i; i--)
if(i == newTOCIndex)
_tocRoots.setItemAt(currentItem, newTOCIndex);
else
_tocRoots.setItemAt(_tocRoots.getItemAt(i-1), i);
else
for (i = currentTOCIndex; i <= newTOCIndex; i++)
else
function getCurrentTOCIndex():int
var result:int;
for (i = 0; i < _tocRoots.length; i++)
if (_tocRoots.getItemAt(i) is TocMapLayerItem && TocMapLayerItem(_tocRoots.getItemAt(i)).layer === layer)
result = i;
break;
return result;
Hope that fixes the issue.
