Original User: PiHellzHi, I'm trying to create a symbology with a color scheme name "Cool Grey". I have tested and try a lots of thing and different method but nothing works as I wish.I think my problem is in the second code wrap. Thanks you for your help
Sub CreateAndApplyUVRenderer()
Dim pMxDoc As IMxDocument
Set pMxDoc = ThisDocument
Dim pWorkspaceFactory As IWorkspaceFactory
Dim pWorkspace As IWorkspace
Set pWorkspaceFactory = New ShapefileWorkspaceFactory
Set pWorkspace = pWorkspaceFactory.OpenFromFile _
("U:\Mise en oeuvre\", 0)
Dim pFeatureWorkspace As IFeatureWorkspace
Dim pFClass As IFeatureClass
Set pFeatureWorkspace = pWorkspace
Set pFClass = pFeatureWorkspace.OpenFeatureClass _
("Caserne_Operationnel")
Dim pFLayer As IFeatureLayer
Set pFLayer = New FeatureLayer
Set pFLayer.FeatureClass = pFClass
Dim pGFLayer As IGeoFeatureLayer
Set pGFLayer = pFLayer
Dim pQueryFilter As IQueryFilter
Set pQueryFilter = New QueryFilter 'empty supports: SELECT *
Dim pFeatCursor As IFeatureCursor
Set pFeatCursor = pFClass.Search(pQueryFilter, False)
'** Make the color ramp we will use for the symbols in the renderer
Dim rx As IRandomColorRamp
Set rx = New RandomColorRamp
rx.Name = "Cool Grey" ' Première tentative pour la rampe de couleur prédéfinis
rx.MinSaturation = 20
rx.MaxSaturation = 40
rx.MinValue = 85
rx.MaxValue = 100
rx.StartHue = 76
rx.EndHue = 188
rx.UseSeed = True
rx.Seed = 43
'Add class breaks renderer code here.
Dim pUVR As IUniqueValueRenderer, n As Long
Set pUVR = New UniqueValueRenderer
Dim symd As ISimpleFillSymbol
Set symd = New SimpleFillSymbol
symd.Style = esriSFSSolid
symd.Outline.Width = 0.4
pUVR.FieldCount = 1
pUVR.Field(0) = "NO_CAS_OP"
pUVR.DefaultSymbol = symd
'pUVR.ColorScheme = "Cool Grey" ' Deuxième tentative pour la rampe de couleur prédéfinis
'******* Code pris en référence sur le site de ForumSIG ****************
'http://www.forumsig.org/showthread.php?t=8562&highlight=symbologie+add
Dim pFeat As IFeature
n = pFClass.FeatureCount(pQueryFilter)
'** Loop through the features
Dim i As Integer
i = 0
Dim ValFound As Boolean
Dim NoValFound As Boolean
Dim uh As Integer
Dim pFields As IFields
Dim iField As Integer
Set pFields = pFeatCursor.Fields
iField = pFields.FindField("NO_CAS_OP")
Do Until i = n
Dim symx As ISimpleFillSymbol
Set symx = New SimpleFillSymbol
symx.Style = esriSFSSolid
symx.Outline.Width = 0.4
Set pFeat = pFeatCursor.NextFeature
Dim x As String
x = pFeat.Value(iField) '*new Cory*
'** Test to see if we've already added this value
'** to the renderer, if not, then add it.
ValFound = False
For uh = 0 To (pUVR.ValueCount - 1)
If pUVR.Value(uh) = x Then
NoValFound = True
Exit For
End If
Next uh
If Not ValFound Then
pUVR.AddValue x, "Name", symx
pUVR.Label(x) = x
pUVR.Symbol(x) = symx
End If
i = i + 1
Loop
'** now that we know how many unique values there are
'** we can size the color ramp and assign the colors.
rx.size = pUVR.ValueCount
rx.CreateRamp (True)
Dim RColors As IEnumColors, ny As Long
Set RColors = rx.Colors
RColors.Reset
For ny = 0 To (pUVR.ValueCount - 1)
Dim xv As String
xv = pUVR.Value(ny)
If xv <> "" Then
Dim jsy As ISimpleFillSymbol
Set jsy = pUVR.Symbol(xv)
jsy.Color = RColors.Next
pUVR.Symbol(xv) = jsy
End If
Next ny
Dim hx As IRendererPropertyPage
Set hx = New UniqueValuePropertyPage
pGFLayer.RendererPropertyPageClassID = hx.ClassID
Set pGFLayer.Renderer = pUVR
pFLayer.Name = "Caserne_Operationnel"
pMxDoc.FocusMap.AddLayer pFLayer
pMxDoc.ActiveView.Refresh
pMxDoc.UpdateContents
End Sub
