Original User: mathieu_fortier
If you want to have the centroid of 2 polygons in an other projection, you have to calculate the centroid with the projected geometries. When you reproject points, they gonna stay at the same place. This is not the fact with polylines and polygons because, depends on the new projection, the geometries will move and the surface will change also.
Mathieu Fortier
