AnsweredAssumed Answered
Administering an SDE database server 10 help
Question asked by geonetadmin on Aug 18, 2010
Latest reply on Aug 19, 2010 by geonetadmin
Original User: alnesbit
Hello all,
I am looking for the online help and pdfs for Administering ArcSDE database servers and the help section called 'Administering a database server'. For 9.3 these are here: http://resources.esri.com/help/9.3/geodatabase/pdf/dbserver.pdf
and
http://webhelp.esri.com/arcgisdesktop/9.3/index.cfm?TopicName=Administering_a_database_server
But where are they for 10? Or can I just use the same ones? I expect it has changed a little since 9.3, right?
All I see for 10 is http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#/Essential_readings_about_the_geodatabase/003n00000003000000/
and
http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#//000500000002000000.htm
Which seems to just be "Administering Geodatabases licensed through ArcGIS Server Enterprise". Where's the SQL Server Express workgroup level 10 help?
Thank you,
Outcomes
