Layers
2846
7
08-17-2010 05:07 AM
DanielTuracek
i have dataframe with these layers:
and i have this code:
Sub a()
    Dim s As String
    Dim aLayer As ILayer
    Dim a, c As String
    Dim pMxdoc As IMxDocument
    Set pMxdoc = Application.Document
    Dim pMap As iMap
    Set pMap = pMxdoc.FocusMap
    Dim b As String
    b = pMap.name + ":"
    Dim pEnumLayer As IEnumLayer
    Dim pId As New uid
    Dim pparentlayer As ILayer
    Dim kolekcia As New Collection
    Dim out As Variant
    Set pEnumLayer = pMap.LAyers
    Set aLayer = pEnumLayer.Next
Do Until aLayer Is Nothing
  Set pparentlayer = GetParent(pMxdoc.FocusMap, _
                    aLayer)
    If Not pparentlayer Is Nothing Then
        a = a + pparentlayer.name + ":"
    End If
        s = b + a + aLayer.name
        out = s & Chr(13)
        kolekcia.Add out
Loop
    For Each out In kolekcia
        List = List & out
MsgBox b & Chr(13) & List
End Sub
Function GetParent(pMap As iMap, aLayer As ILayer) As ILayer
    If pMap.LayerCount = 0 Then Exit Function
    Dim pUID As New uid
    pUID.value = "{EDAD6644-1810-11D1-86AE-0000F8751720}"
    Set pEnumLayer = pMap.LAyers(pUID, True)
    Dim pCLayer As ICompositeLayer
    Set pCLayer = pEnumLayer.Next
Do Until pCLayer Is Nothing
    Dim k As Integer
    For k = 0 To pCLayer.Count - 1
        If pCLayer.layer(m) Is aLayer Then
            Set GetParent = pCLayer
        End If
    Next k
Loop
End Function
which gives me this msgbox:
As you can see i want to get something like layers tree from this code. but there is mistake."New group layer" is repeatly appearing there where it isnt correct.
can anybody responsible who is good programmer explain what i doing bad?
Or have anyone of you another code for that?
by Anonymous User
Not applicable
Original User: thaviti
Please find the explanation against lines
Sub GetLayerNames()
Dim s As String
Dim a, c As String
Dim pMap As IMap
Set pMap = pMxdoc.FocusMap ''get the active map
Dim b As String
b = pMap.Name + ":"
Dim pId As New UID
Dim coll As New Collection
Dim out As Variant
Set pEnumLayer = pMap.Layers(Nothing, False)
''As second parameter is False, this Gets the immediate Layers in the map. i.e. only the direct layers ''under map
Set aLayer = pEnumLayer.Next ''loop through retrieved layer enumeration
Dim parentLayerName As String
coll.Add b & aLayer.Name ''add the layer name appended with map name to the collection
''If the layer is GroupLayer then process its child layers
If (TypeOf aLayer Is IGroupLayer) Then
''Pass the layer and the layer full name (Map name + layer name) to the method along with the ''collection variable
AddLayerNames aLayer, b & ":" & aLayer.Name, coll
End If
''Get the next layer in the enumeration and process the same
Loop
For Each out In coll
List = List & out & vbNewLine
End Sub
''This method adds the child layer name's in the group layer to the collection. If the child layer is ''also a group layer then that child layer itself is proceed with this method to get its child layer ''names and the same to the collection variable.
Sub AddLayerNames(pGroupLayer As IGroupLayer, pGroupLayerFullName As String, ByRef collectionVariable As Collection)
If pGroupLayer Is Nothing Then Exit Sub
Dim compLayer As ICompositeLayer
Set compLayer = pGroupLayer
Dim childLayer As ILayer
Dim i As Integer
For i = 0 To compLayer.count - 1
Set childLayer = compLayer.Layer(i)
collectionVariable.Add pGroupLayerFullName & ":" & childLayer.Name
''append the child layer name to parent layer full name and pass the same to the method to process ''for child layers
If TypeOf childLayer Is IGroupLayer Then
AddLayerNames childLayer, pGroupLayerFullName & ":" & childLayer.Name, collectionVariable
End If
End Sub
by Anonymous User
Not applicable
Following code may help u.
Sub GetLayerNames()
Dim s As String
Dim a, c As String
Dim pMap As IMap
Dim b As String
b = pMap.Name + ":"
Dim pId As New UID
Dim out As Variant
End If
Loop
End Sub
Dim i As Integer
End If
End Sub
DanielTuracek
thank you very much
you saved my job 🙂
DanielTuracek
One more questions:
I used your code(btw: code is great) but i need add "layer id number" for each layer. Can you give me one more advice.
Sub NazvyVrstiev()
Dim s As String:                    Dim a, c As String
Dim pMxdoc As IMxDocument:          Set pMxdoc = Application.Document
Dim pMap As iMap:                   Set pMap = pMxdoc.FocusMap
Dim b As String:                    b = pMap.name + ":"
Dim kolekcia2 As New Collection:    Dim kolekcia3 As New Collection
Dim out0 As Variant:                Dim out00 As Variant
Dim i As Integer
i = -1
Set pEnumLayer = pMap.LAyers:       Set aLayer = pEnumLayer.Next
''I NEED ADD LAYER ID NUMBER FOR EACH LAYERS
    i = i + 1
    out0 = i
    kolekcia3.Add out0 & "/" & b & ":" & aLayer.name
Loop
For Each out0 In kolekcia3
List2 = List2 & out0 & vbNewLine
MsgBox List2
'' I NEED THIS ID FOR THIS COLLECTION
Set pEnumLayer = pMap.LAyers(Nothing, False):   Set aLayer = pEnumLayer.Next
    out00 = b & ":" & aLayer.name
    kolekcia2.Add out00
        Vrstvy aLayer, b & ":" & aLayer.name, kolekcia2
    End If
Loop
For Each out00 In kolekcia2
List = List & out00 & vbNewLine
MsgBox b & vbNewLine & List
End Sub
Sub Vrstvy(pGroupLayer As IGroupLayer, pGroupLayerFullName As String, ByRef kolekcia As Collection)
Dim SubLayer As ILayer
Dim i As Integer
For i = 0 To compLayer.Count - 1
    Set SubLayer = compLayer.layer(i)
    Dim s As String
    s = pGroupLayerFullName & ":" & SubLayer.name
    kolekcia.Add s
    If TypeOf SubLayer Is IGroupLayer Then
    Vrstvy SubLayer, s, kolekcia
    End If
End Sub
by Anonymous User
Not applicable
what do u mean by Layer ID?
If it is the Layer index in the map, then the index exists only for top most layers in the map / Data frame.
Child layers in the GroupLayer will have an indexing starts from 0 gain.
Hence be very clear what u would like to gather
DanielTuracek
Ok, so I need get specifications for layers something like ID.
For Each layer. this is example:
Dim i As Integer
i = -1
i = i + 1
out0 = i
Loop
MsgBox List2
If know how to mark each layer in your code, it will be great.
Your code is OK , but i dont understand how its work.
thanks again for your replying
by Anonymous User
Not applicable
Sub GetLayerNames()
Dim s As String
Dim a, c As String
Dim pMap As IMap
Dim b As String
b = pMap.Name + ":"
Dim pId As New UID
Dim out As Variant
End If
Loop
End Sub
Dim i As Integer
End If
End Sub
MichaelaRepkova
hi,
i got the same problem but in Java.
this is my code:
public class interpolacia {
public static void main(String[] args)  {
  ServerInitializer serverInitializer = null;
  ServerConnection connection = null;
  try
     serverInitializer = new ServerInitializer();
     serverInitializer.initializeServer("esprit", "misa", "a");
      connection = new ServerConnection();
      connection.connect("michalavirtual");
      IServerObjectManager som = connection.getServerObjectManager();
      IServerContext context = som.createServerContext("nova", "MapServer");
      MapServer ms = (MapServer)context.getServerObject();
      String nazov = ms.getDefaultMapName();
      MapServerInfo mapinfo = (MapServerInfo)ms.getServerInfo(nazov);
      IMapLayerInfos maplayerinfo = mapinfo.getMapLayerInfos();
     for (int i = 0; i < maplayerinfo.getCount();  i++)
     if (maplayerinfo.getElement(i).getSubLayers() == null)
       int m = i;
       do {
        m = maplayerinfo.getElement(m).getParentLayerID();
        System.out.println("<"+maplayerinfo.getElement(m).getName()+">");
       while (maplayerinfo.getElement(m).getParentLayerID() != -1);
       System.out.println(maplayerinfo.getElement(i).getName());
             catch (AutomationException ae)
           System.err.println("Caught AutomationException: " + ae.getMessage() + "\n");
           ae.printStackTrace();
       catch (IOException e)
           System.err.println("Caught IOException: " + e.getMessage() + "\n");
the result of this is:
<pod-podgrupa>
<podgrupa1>
<grupa1>
Banska_Bystrica
<pod-pod-pod-podgrupa>
<pod-pod-podgrupa>
<pod-podgrupa>
<podgrupa1>
<grupa1>
KOTY
<pod-pod-podgrupa>
<pod-podgrupa>
<podgrupa1>
<grupa1>
Riecna_siet_Clip
<grupa1>
Riecna_siet
<grupa2>
Banska_Bystrica_Select
<pogrupa2>
<grupa2>
katastralne_uzemie
i need make it reverse like
<grupa1>
<podgrupa1>
<pod-podgrupa>
Banska_Bystrica
<grupa1>
<podgrupa1>
<pod-podgrupa>
<pod-pod-podgrupa>
KOTY
can somebody help me?
