Original User: ukvick
Hi!
I am looking for a solution in order to export a predefined layout (map) with the data that I am interested of within to PDF and have the advanced options taking part of the export options. I do not see how to do it. I succeed with the export MXD to PDF but I can not add the advanced options part. The thing is that I have to create a multiple layouts with pdf layers and feature attibutes on it. All of this it has to be done in ArcGIS 9.3. I have seen that you can do something like that in ArcGIS 10 but I don't have it yet.
Any ideas?
Sincerely yours
Felipe
PD.- I got this code for VB 6 but it does not work at all:
Sub SetAttributeExportsForPdf()
Dim pMxDocument As IMxDocument
Dim pMap As IMap
Dim pEnumLayer As IEnumLayer
Dim pLayer As ILayer
Dim pId As New UID
Dim pLayerFields As ILayerFields
Dim pFeatureLayer As IFeatureLayer
Dim pFieldInfo As IFieldInfo2
Dim iCurField As Long
Set pMxDocument = Application.Document
Set pMap = pMxDocument.FocusMap
pId = "{E156D7E5-22AF-11D3-9F99-00C04F6BC78E}"
Set pEnumLayer = pMap.Layers(pId, True)
pEnumLayer.Reset
Set pLayer = pEnumLayer.Next
Do While Not pLayer Is Nothing
Debug.Print pLayer.Name
If TypeOf pLayer Is ILayerFields And TypeOf pLayer Is IFeatureLayer Then
Set pLayerFields = pLayer
Set pFeatureLayer = pLayer
iCurField = 0
Set pFieldInfo = Nothing
For iCurField = 0 To pLayerFields.FieldCount - 1
Set pFieldInfo = pLayerFields.FieldInfo(iCurField)
If (pLayer.Name = "sign_total_Qty") And (pFieldInfo.Alias = "sign_total_Qty" Or _
pLayerFields.Field(iCurField).Name = pFeatureLayer.DisplayField) Then
pFieldInfo.Visible = True
Else
pFieldInfo.Visible = False
End If
Debug.Print " Field='" & pFieldInfo.Alias & "'" & " Visiblity = " & pFieldInfo.Visible; ""
End If
Loop
End Sub
